Old 12-11-2019, 05:20 AM   #84 (permalink)
ps2fixer
92 Camry - '92 Toyota Camry LE
90 day: 26.81 mpg (US)
97 Corolla - '97 Toyota Corolla DX
90 day: 30.1 mpg (US)
Red F250 - '95 Ford F250 XLT
90 day: 20.34 mpg (US)
Matrix - '04 Toyota Matrix XR
90 day: 31.86 mpg (US)
White Prius - '06 Toyota Prius Base
90 day: 48.54 mpg (US)
FYI, water cooled mowers is a quite old. Honda mowers got all of those checks too, liquid cooled, oil pump + filter, twin cylinder, rubber engine mounts, shaft drive with a true gear to gear transmission but shifts like a hydro-static.
Not much goes wrong with these, deck rusts out after 20+ years of use if not cleaned ever, pto clutch + break generally is the first clutch to go and the second clutch, the drive clutch is the other wearable item. Change the belt every like 15-20 years and keep the fluids in check. Not sure if it's true, but I read that JD assisted with the design with Honda so probably why the two are similar.
Btw, did I say this was a mid to late 80's lawn mower? They also made some models in the 90's.
The Following 2 Users Say Thank You to ps2fixer For This Useful Post:
Daschicken (12-28-2019), slowmover (12-14-2019)
