Old 12-12-2019, 09:39 PM   #7955 (permalink)
oil pan 4
Yeah they can't down play or dismiss the pole movement any more. Now all they can do is distract and pretend like it isn't happening.
As of late 2019 the south pole is half way to Australia.
Something that definitely hasn't happened in the last 400 years and doesn't appear to have happened within the last few thousand years.
This is not correct. The Antarctica was gaining up until 2014, when it set a record high area - but since then it is already at record lows.
This is huge, and and shocking - record high to a record low in just a few years.
Calling the time period between 2014 and now is not climate or proof of climate change. Even the ipcc uses averages of temperature, ice coverage, rain fall data and then lumps the data into 30 year blocks.
