12-15-2019, 02:34 PM
#7973 (permalink)
You attached a picture right?
[helpful instruction]
I search like that because I remember pictures.
No joy.
Originally Posted by Attachment Statistics
You are currently using 212.6 KB to store 3 uploaded attachments.
All from Thread: Local Motors Strati
Post: Local Motors Strati
08-24-2014 08:17 PM _______________
Links from Suspicious 0bservers this morning:
https://www.sciencedirect.com/scienc...21818119305806
Evidence against a long-term control on Earth climate by Galactic Cosmic Ray Flux
Changes in Galactic Cosmic Ray (GCR) flux have been proposed by some as the main factor controlling Earth's climate. This hypothesis, which invokes enhanced formation of low clouds due to ionization of atmospheric aerosol by GCR flux as a control mechanism, implies that climate sensitivity to atmospheric CO2 levels is overestimated.
[snip]
We conclude that, the putative role of GCR flux as a cause for medium to long term (103–5 yr) changes in Earth's climate is not supported by evidence.
https://www.sciencedirect.com/scienc...73117719308026
Sunspot cycle prediction using Warped Gaussian process regression
Solar cycle prediction is a key activity in space weather research. Several techniques have been employed in recent decades in order to try to forecast the next sunspot-cycle maxima and time.
[snip]
Cycle 25 is expected to last from 2019 to 2029, with a peak sunspot number about 117 (110 by the median) occurring most likely in 2024. Thus our method predicts that solar Cycle 25 will be weaker than previous ones, implying a continuing trend of declining solar activity as observed in the past two cycles.
ESA - CryoSat maps ice shelf on the move
About three-quarters of the Antarctic coastline consists of ice shelves. They are permanent floating extensions of the ice sheet that are connected to and fed by huge ice streams draining the interior ice sheet. Ice shelves form as the ice sheet flows towards the ocean and detaches from the bedrock beneath. The advance or retreat of ice shelves is determined by a balance between mass gain from the flow of ice behind and snowfall on top, and mass loss through ocean melting at the base or iceberg calving at the edge.
- Filchner-Ronne ice shelf advance 2011–18
________________
Just for fun: When a Mantis Shrimp Fights a Disco Clam, It Meets Its Match
It's supercavitation vs dazzle camouflage.
