Old 12-17-2019, 11:32 AM   #267 (permalink)
NeilBlanchard
Please quantify the magnitude of this advantage. The two bumpers are 262 pixels apart in that image and the tow strap only rises 8 pixels. It is simple math. Come on, do it.
It IS an advantage. You can have a lightweight tractor, and attach to tow hitch in the right location - and all the weight of the tow load transfers to the tractor wheels.
All else being equal - the tow hitch points must be the same height IF you want to test the actual towing power.
aerohead (12-18-2019)
