Originally Posted by TheEnemy
They did so with the Model X, performance wise it did real well. It was a worst case scenario, the trailer empty weighed as much as the tow rating so it wound up being the highest aero drag possible. It climbed faster than most were capable of, and the regenerative braking meant they rarely had to hit the brakes. They did find that they got about 1/3 of the range, they were not driving conservatively. Engineering Explained did a good episode on why the range is so short.
I am expecting the Cybertruck to loose about 50% of its range pulling my trailer, which is why I want the option to get the larger battery pack for the dual motor.
It wasn't the worst aerodynamics possible, it was a nice v nosed cargo trailer if I remember right. There are plenty of 8' wide, 10' high campers with an awning on the side and a A/c on the roof that are within the tow rating, and would be a more common usage for a $100k family car. Not many painters or carpet cleaners are going to use the model X to tow their cargo trailer. When they lost 2/3 of the range they were towing a teardrop sized micro camper. The range dropping to just 1/3 is going to be a best case scenario towing a real camper behind the Cybertruck. Next problem will be with twice the battery, it's going to take twice as long to recharge.
