Old 12-19-2019, 10:07 PM   #60 (permalink)
M_a_t_t
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
To keep track of the timeline of this project, I started another thread asking about cfd results.
https://ecomodder.com/forum/showthre...lts-38038.html
I have the parts to change the gas tank, timing belt, water pump, thermostat (it takes like 4 miles to warm up with an ~85% grill block), wideband oxygen sensor, and the idler pulley for the manual steering and non a/c version of the car. I'm still running alternator-less, but I can safely delete the P/S and A/C (weight removal) and still be able to run the belt as back up.
For the aero aspect I have 3 sheets of 2*4 coroplast and plenty of cardboard for templates. I also got a roll of lawn edging. I can get more coroplast at the home depot, but the closest one is 20 miles away. Thats okay because I need to rack up some miles to finish calibrating the MPGuino anyway.
I made the DIY version of lean burn based on ecoscorts description of Tygens module. I haven't installed it yet because I want to put the wideband in first.
Tonight I swapped the idler pulley and had to remove the a/c compressor and power steering pump pulley to clear the path for the belt. Turns out that the idler must not be in the same spot or something because the belt that rockauto and autozone says is the right length doesn't fit.
Tomorrow I get the last few parts and then after I change the struts on my moms car I will get started on the car.
@93Cobra, I think you are right about not having lean burn. Over the last few weeks I never saw (mpguino) or felt lean burn engage. Whether thats because its a tracer or whatever the reason is I am adding it.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
