Old 12-24-2019, 10:48 PM   #61 (permalink)
M_a_t_t
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
I had a busy weekend; saturday I changed the gas tank, sunday I did the timing belt and water pump, and yesterday I did the thermostat. Everything was smooth sailing until the thermostat. One of the bolts broke, I welded a nut to the stud and it just broke the stud. Twice. I ended up drilling and tapping it. However, it looks like someone has done that on one of the other bolts and when I went to tighten that one down it didnt get tight . I removed a/c and p/s stuff as well (looped the p/s lines at the rack). I don't have any pictures on my phone, I think I have some on my camera at home.
Lastly I removed the downpipe from the exhaust manifold and welded an o2 sensor bung in. I forgot to test the sensor so I didnt put the downpipe back on yet. I also am going to try and put the coolant heater from my van in. Its 1500w so its a little oversized, but atleast it will warm up quickly .
Pictures of the o2 install:
Checking fitment and marking location
Pipe removed and on the workbench
I'm using a spark plug non fouler as my bung
It was too long to get good reach into the pipe so I cut it at the external threads
I used a flap disc on the outside and a deburring tool on the inside. Helps to get it to sit still while tacking it.
Hole drilled
Pipe reinstalled (loosely) to confirm fitment
Final weld. Not the prettiest, but it should get the job done.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
