Old 12-26-2019, 11:45 AM   #4 (permalink)
kach22i
We just had someone in the forum do a similar grille bock, then he discovered the Grille Block Summary thread.
https://ecomodder.com/forum/showthre...ary-13768.html
In short, start from top down, not bottom up as you have done.
It does look nice though.
You've covered the best ram-air location for cooling.
The over-fascia is encouraging airflow under the nose,which is a no-no unless you have a full belly pan,and it will increase front lift at speed.
Take a look at any Tesla and follow their lead.
Will a splitter help now?
Or will a spiltter just increase down-force and drag?
aerohead (12-26-2019), SmellyCat (12-30-2019)
