Old 12-27-2019, 04:45 PM   #6 (permalink)
kach22i
It had one to begin with.Adding in one now is going to add downforce-induced drag.The moment arm in front of the front axle has been lengthened.These changes are subtle and would require virtual fortunes to properly 'tune.'
Thank you for answering my question, yes you are right, it did have a splitter of sorts prior to modification.
Possible lifting problem now.
I am going to suggest starting over.
Upper grill block is the standard.
And lose that bug deflector.
If there are dummy openings that do nothing or are there just for styling, then by all means seal them up, or keep them sealed as may be the case on the outer ones.
SmellyCat (12-30-2019)
