Originally Posted by MetroMPG
Definitely have to research the seat issue more.
For now, I'm replacing cardboard with coroplast.
Kammback first...
how did you make that? i don't think it will effect the visibility too much on my tahoe
I noticed there is a circle of turbulent air in the back the picks up water from the ground (when it's not raining the water still gets on the the back glass from the wet ground) i did not see this on other suvs
I also suggest if your going to use it put a reflective sticker on it most jurisdictions would claim you have too much over hang on the car i see california it's can be less then 4 feet overhang 24604.(a)
do you think this can be done as long as it's less then 4 feet I should be ok it would only be the top portion were the glass is as not to block the light signals...
