Old 12-28-2019, 09:20 PM   #22 (permalink)
EcoCivic
I installed a temp gauge about a month ago and the transmission frequently doesn't even reach 100 degrees in cooler weather. I was cruising down the highway with the converter locked in about 30 degree weather and the trans temp was running a 75-80 degrees F. Is this bad for the trans? And if not, how bad is it for fuel efficiency? Thanks
