Hybrid or hybridize
I found some LG 43 Ah cells that are relatively cheap over here and was thinking of buying them and putting them to use. (Same cells as hyundai ioniq)
I can buy something like a CR-Z and put the pack in parallel.
Ideally the altermotor route would be the beat option. But i do not know how to drive the altermotor. I am however capable of using the canbus to calculate a reference for the motor. I.e something like power on low rpm and cutoff at 2000 rpm and recharge when gas pedal not depressed and rpms above 2500 (obviously i am engine braking) or when brake pedal is applied and car is moving.
What is reasonnably possible.
