Old 12-31-2019, 08:29 AM   #9 (permalink)
SmellyCat
I did not notice it handling worse. I hit 80 a few times. With almost 300k on the whale, handling ain’t that tight any more. Summer heat would be an issue. I can easy pull the cover off or cut some Gills in it. Under side of this has a gas tank and spare tire hanging low. Today I can remove the lower and just block the upper part. Let’s see what happens.
