Old 01-03-2020, 02:06 PM   #55 (permalink)
GK13
Belly pan and airdam is like belt and suspenders.
Ok. Then since it does have a full belly pan, you don't think that having the air dam closer to the ground would help anything? I thought that by having the car so high in the air, that increased drag as well? I thought that was one of the main things with an air dam.
Also, if I'm not doing the air dam, how would I go about getting air around the front tires more efficiently? I know I've heard of people using mud flaps in front of the tires to try and redirect airflow. Does that provide enough benefit you think?
I'm having a hard time figuring out what else I can do to get more mpg squeezed out of the Rav4.
The Following User Says Thank You to GK13 For This Useful Post:
aerohead (01-04-2020)
