Old 01-04-2020, 05:36 PM   #60 (permalink)
freebeard
You'd be able to design cars of Cd 0.10 with his data.
Given sufficient frontal area, you could even use a RAV4 as the donor vehicle.
My parents had a vacuum-form machine like the one you describe, with a capacity of 1 1/2x2ft. It had a heating bed on one side, and a vacuum bed on the other, of a piano hinge. One could probably fabricobble one with infrared heat lamps and a shopvac.
tip: Heat the sheet vertically, instead of swinging it 180°.
What the headline giveth, the last paragraph taketh away. -- Scott Ott
