Tomorrow is one week until the challenge is over. I am behind where I hoped to be. I got sick over the holidays and didn't really feel like working on the car until the Tuesday after christmas. I put the car back together from the maintenance stuff on wednesday. I installed a new speedo cable because the old one was broken (which is why the speedo/odo didn't work). After driving for a bit to make sure everything was working right the vss (vehicle speed sensor) went out and the car wouldn't shift out of first. I fought with it to get it out because it was seized in the transmission. I ended up shortening a drill bit and drilling and tapping the sensor. Then I used a threaded rod (7/16") and a pipe as a puller. Worked flawlessly. Now the speedo and odo work
. That brings us up to this morning.
I filled the tank up and went out to home depot and got 3 4*8 sheets of coroplast. I also bought some insight rims WITH potenza re92's for 220 shipped. The tires are in better overall condition then the ones that were on the car. Dropped 8 lbs per wheel. They are missing the center caps though. I only put the fronts on in this picture, I have a full set that are now on.
I did drop a tire size or two though. There was 2 different sizes on there originally: 175/65r14 and 175/70r14 vs the re92's 165/65r14.
The only other things I have done is install the controller for the wideband, still need to wire it into the car but I have found which wires I'm tapping into. I also installed the switch and ID'd the wires for the leanburn switch. Now I need to make a detailed plan for the wheel skirt and nosepiece. I think it will be easier to combine the boat tail/wheel spats on the front into a nosepiece as well as a belly pan.
As an aside, I got featured in the local paper and got a quick reference on one of the Indianapolis news channels. I would post a link to the paper, but I feel like that would give my location away. That was Dec 30th. I've had 2 random people recognize my car out in the wild already.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
