Theoretically all batteries with the same Chemistry andC rating change at the same time (if you are capable of supplying the amps. From drone batteries to car batteries.
If expense and weight was not an obstacle, then having a massive battery would be a solution to the charge time problem. You have to stop ever so often, and when you do, you could dump enough kwh to drive several hours as fast as pumping gasoline.
