Old 01-06-2020, 04:59 PM   #448 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Update with pictures on the headlight bulbs. Finally got off my butt and measured the wattage of these.
As I said before, I'm pretty happy with how little light scatter there is, and with the clean cutoff, despite being LEDs in housings made for halogens.
On Amazon they're advertised as "80w - 9600 lumen" (40w per bulb). The 9600 lumen claim was clearly bunk, but turns out so was the 40w per bulb claim. With my meter I measured 2.63 amps low beams and 3.93 amps high beams, which works out to around 18w low / 27w high per bulb, using 13.8v as a reference. If wattage scaled linearly, to hit their advertised 40w, these bulbs would need ~20.4v.
They're really not bad. Low beams are 1/3 the wattage of halogens with similar usable light output, but if I had to buy again I'd look around to see if I could find something a bit brighter. The images above exaggerate their light output a bit compared with what my eyes see.
I like those lights but they burn out really fast and linearly over about a year and a half. Seems to me like there should be a market to replace the led chip on them. I ended up just going back to the oem osram lights for me. Can't beat oem quality that last for 8 years.
*I assume they are being overheated constantly as the reason probably.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
