Old 01-06-2020, 07:38 PM   #32 (permalink)
Tahoe_Hybrid
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
Originally Posted by ksa8907 View Post
Speaking of towing, we pulled a uhaul 4x8 with about 800 lbs in it, cabin filled to the bursting point, along with two bicycles mounted on the roof at up to 85mph cruising and the trans never went over 171°F. So yes, the cooling is quite good!
yeah make sure Not to use the Revise gear when towing (just don't put yourself in that situation )
you will damage the CVT revise gear also use the M gear m3 if you want AFM M4 give you full power V8 with E-Assist (besure to turn on the A/C so you don't accidentally deep CYCLE the high voltage battery i.e getting the State of charge too high) it will be worth the slight extra gas
as that HV battery is expensive.... so also good to use the A/C in the winter occasionally for 5min or so (this will keep the seals in good condition for many many years )
if you can afford it get 91/93 octane for the MAX amount of MPG and MAX low end power i get about 27mpg on the highway with it worth the extra 30 cents as 87 octane would cost me over 5$ to go 27 miles
i save 1.34 per gallon with the high octane fuel chevron or mobil are the best as they don't screw you on the octane you buy Shell/arco have screwed me on the octane when I paid for 91 octane they gave me 87 octane it happened at 3 stations for both arco and shell. what a scam they are pulling
