Old 01-07-2020, 12:23 AM   #36 (permalink)
Tahoe_Hybrid
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
Originally Posted by EcoCivic View Post
I think you are confusing a CVT with a DCT. Most CVT transmissions use a torque converter (a fluid coupling) like a regular auto instead of a clutch, so they aren't harmed by crawling forwards or backwards. However, some CVTs like the ones found in some Hondas use a start clutch instead of a torque converter, so it's best to avoid crawling in those just like with a DCT.
A DCT (Dual clutch transmission) has no torque converter. Instead, it has clutches that may overheat from slipping and fail if you crawl for a long time, especially under load. The reason for this is because it can't fully engage the clutches until you reach a certain speed or the engine would stall (like letting the clutch out at too low of a speed in a manual transmission). Therefore, the clutches must slip. This quickly makes a lot of heat, which can destroy the clutches if done repetitively or for extended periods of time, especially under load.
Gm says it's a CVT or as they call it a EVT
Continuous Electric Ratio Hybrid Transmission With 4 Fixed Gears.
Gear Ratios
1st — 3.69:1
2nd — 1.70:1
3rd — 1.00:1
4th — 0.73:1
EVT #1 — Infinity to 1.70:1
EVT #2 — 1.70 to 0.50:1
Reverse — Infinity to 1.70:1
