Old 01-09-2020, 08:07 AM   #24 (permalink)
EcoCivic
Update: I finished installing the heat exchanger setup and it works very well now that I finally got the AN fittings to stop leaking oil. I seem to have gained about 40-50 degrees on my oil warmup. The oil was warmed up to around 100 degrees at best once the coolant warmed up before I installed the heat exchanger, but now That I installed the heat exchanger the oil is warmed up to around 140 to 150 degrees once the coolant is warmed up, and within 5 minutes or so it is up to coolant temp of around 180-185 degrees. The oil temp always stays within a couple degrees of coolant temp while driving down the road.
This setup is also very effective at cooling the oil off. I ran the oil up to around 200 degrees and turned the radiator fans on, and within a minute or two it was back down to around 185 degrees. That will sure be nice in the summer here! I don’t know what the oil temp was reaching before because I had no gauge at that point, but surely much hotter than the coolant.
I am happy with the results of this 30 plate 4 X 8 inch heat exchanger brick, but with the results I am seeing from this I don’t think I would be happy with the results of an OEM style oil cooler between the oil filter and the block, I don’t think something with that little surface area that a lot of oil bypasses would do what I wanted. But if someone has a vehicle with that type of oil cooler and you would like to do testing to see how effective it is that would be cool!
The Following User Says Thank You to EcoCivic For This Useful Post:
Daschicken (01-09-2020)
