Old 01-10-2020, 03:01 PM   #270 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by Tahoe_Hybrid View Post
you so crazy to use #10 with a 300amp breaker
or you just wanted a incandescent bulb under the hood?
you need at lest 4/0 wire for 300amp breaker (short run) longer runs will need 350 gauge wire(350 is a industrial sized wire)
trying to start a fire?
Probably just too big. It will never ever even get close. The Prius hardly uses the 12v system.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
