Old 01-10-2020, 10:21 PM   #2 (permalink)
oil pan 4
My house came with a wp elite serries, sounds pretty much the same idea.
I put in a hot water heater circulation pump on the furthest lines in the house controlled with a hand timer and 110F thermostat. So it times out or the thermostat stops it.
This is how I do it.
1 let the dogs lock the dishes perfectly clean.
2 sling dishwasher soap on the inside and put some in the soap holder.
3 it's close enough to the hot water heater.
4 select the wash cycle I want to use.
5 shut the door.
Yes hot water heaters can produce some hydrogen.
How to load the dishwasher, who cars, just make sure nothing can fall through the bottom and sit on the heating coil and make sure nothing sticks up high or goes through the bottom enough to interfere with the spray bars.
