Old 01-12-2020, 12:17 AM   #12 (permalink)
freebeard
Here I am searching for pusher trailer information before posting... and apparently I already asked about it a few years ago.
It's happened to me, but I wasn't OP.
It's a timely question what with the EV tow questions floating around. I suspect any regulation would be aimed at trailers made from the back half of a pickup. They're sub-optimal. Don't look like one. Not getting pulled over is half the battle.
Why do you ask? Part in hand? What's the use case (gross weight, etc.)?
Here's the rear axle I have on the bench*, but it's intended for a Baja Bug instead of a trailer. It would be sweet in an Airstream Bambi.
* 98lb, 68hp, 10,000rpm. It eats 250-400V.
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
