Old 01-12-2020, 01:34 AM   #274 (permalink)
Tahoe_Hybrid
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
What thread did you get that quote from? It isn't this thread.
As I said, the breaker is probably rated to high. It wasn't meant to protect against drawing too much power, it was meant to protect against a short.
The attempt was to start an Acura on 10 gauge, which would draw close to that amount if it could.
#25
if it's for a second or two a peak power it might be fine 300amp breaker is incorrect for a normal load on #10 it offers no protection
a starter is connected via relay directly to the battery for 300 amps or so they most likely use #4 wire
most car MEGA fuses are 100 to 200amps rated short to ground
The Following User Says Thank You to Tahoe_Hybrid For This Useful Post:
redpoint5 (01-13-2020)
