Old 01-12-2020, 11:58 PM   #49 (permalink)
MN Driver
2000 Honda Insight
Originally Posted by Coreyosaur View Post
My insight cant lean burn up to 70mph.. but I get about 75mpg@61mph. (Fastest I could go while maintaining lean burn in 5th gear.
35psi re72 tire, 0w-16 oil, no aero mods. There's a lot of gains to still be had
I assume you mean RE92 in the stock size, raise the tire pressure for better MPG. You should be able to lean-burn at 70mph on the flat with air conditioning compressor off in warm or hot weather. 61mph should not be the limit.
