Originally Posted by cray54
I have had a hard time finding information about the legalities associated with building a pusher trailer. I have read that some states do not allow re-purposed truck axles on trailers, but have not seen the actual sources of such information.
I'm specifically interested in Massachusetts (since that's where I live), but I am also interested in other states. I'd like to be able to take my trailer on out-of-state trips.
Are there laws preventing such trailers from being used on the road?
Thanks - Chris
Honestly push trailers are a bad idea
unless these are hitch only with no ball??(bad idea to have a powered device on a pivot point) because of torque steer.
you may also need a independent rear suspension.
a solid rear axle, so when the left tire would bounce on a bump the right tire would tilt out and ride along its edge.
that could be a issue with bumps in the road and cause the torque steer
If you have like a SUV
asymmetrical AWD system would do
![EEK!](/forum/images/smilies/eek.gif)
