Originally Posted by Tahoe_Hybrid
Honestly push trailers are a bad idea
unless these are hitch only with no ball??(bad idea to have a powered device on a pivot point) because of torque steer.
you may also need a independent rear suspension.
a solid rear axle, so when the left tire would bounce on a bump the right tire would tilt out and ride along its edge.
that could be a issue with bumps in the road and cause the torque steer
If you have like a SUV
asymmetrical AWD system would do ![EEK!](/forum/images/smilies/eek.gif)
I'm not quite sure I follow. I can't picture how the concept of torque steer (usually used to describe steering inputs during acceleration on an FWD car) would be applied to a solid rear axle on a trailer.
I think, like most design ideas, the parameters need to be set appropriately. When towing and slowing down, the trailer is loading the tow vehicle in a similar way to a pusher trailer. We don't see them jackknifing regularly, because the loads are reasonable. I don't think I share your primary concerns, but I think that is because I'm picturing much lighter loading than you may be picturing.
