Originally Posted by Tahoe_Hybrid
Yes it does
it has v4-DFCO (Fuel shut off) you can watch the O2 sensors hit 0.00 to 0.235 volts that means 100%-75% oxygen... you can actually drive in this mode I found a glitch in the computer system to regenerate,DFCO and speed up on the down hills at the same time . even if it's very very slight
No shell anymore they scammed me , I just use Chevron only
the BEST i have gotten was 31MPG so far around town. so far
55.00% increase over the base EPA mpg
138.46% over the base EPA of a normal 6.0L suburban 1500 (same year/front end)
best on the highway is 26.9mpg (variable speeds)
35% increase over the base EPA mpg
92.85% over the base EPA of a normal 6.0L suburban 1500 (same year/front end)
I think we need to move onto Aero mods as i hit the cap of what hypermile can do
You would need a wideband to verify, I am very curious however I would still contend it does not have a "lean burn".
