So I wanted to update on this car. Couldn’t calibrate speedometer or swap the cluster (local dealer couldn’t do it, might look for another one). Working on modding bumper cover, debating between air curtain built into side vents, or a simple plastic air deflector at the leading edge of the wheel well. I’ve also decided to add heat extraction vents to the hood, both to reduce drag and to reduce coolant temps during spirited/aggressive driving, especially since the new bumper cover has less grille area than my current one (if you count the unblocked upper grille), being that it has no upper grille.
My last Ecotec project...
