Old 01-16-2020, 10:59 AM   #12 (permalink)
bradlington
All noted and thank for some of the comments - have some more thoghts to ponder over .
As far as the HHO - any combine accululative aid that can assist will make the end result .
Aquatune claim a 60%/40% HHO to water combination make their product work and some (perhaps same as running HHO plus water vaporized via ultrasonic .
Some misconceptions on the HHO is that it is being used as a fuel replacement - most of situations like myself it is a fuel enhancer only to assist the fuel burn and flame wavefront allowing for some benefits .
I had a look at the MPduino a while back and will have a relook into it .I am familiar with pi's and have done some arduino prodject so it should be interesting .
Do the very modern crs after 2010 measure the actual temperature of the fuel being delivered , reason is on carb setups a change in 20 degrees on the fuel can change AFR about 2 AFR .
