Old 01-16-2020, 04:37 PM   #374 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
I have trouble buying the paint process is all that expensive. It really doesn't cost more to paint a $12,000 car vs a $60,000 car yet a $60,000 car easily could have a $12,000 powertrain in it. If the paint process costs more than the powertrain on said car then painting a $12,000 car would cost more than $12,000.
Also if say $5-10k could be saved per car by not painting somebody would have done that in large numbers long ago. Also even with say stainless steel, some of those corrosion steps are still going to be needed as stainless isn't corrosion proof on it's own and what about all the metal under the stainless, is it also stainless? Just the material cost of using stainless rather than mild steel is going to be similar to the painting cost IMO. It's a wash.
Paint is very expensive,
On small parts paint and finish can easily cost more than the “bare” part
Where I work we are converting a lot of small pieces to stainless because it is much cheaper than the coating+ standard steel
The Following User Says Thank You to rmay635703 For This Useful Post:
aerohead (01-18-2020)
