Old 01-17-2020, 12:36 PM   #3 (permalink)
pete c
Originally Posted by aardvarcus View Post
I assume 10 wide and 33 high, how long?
How long does it take to pull the pedals? I know the seat and wheel should be quick, but tiresome to do on a regular basis.
Is there a reason you would not want a box/carrier that goes on the back in a receiver hitch? You could shape it like a tapered body extension and make your MPG improve.
Pedals are off in seconds with a 17?mm wrench. I would likely just pull the left pedal anyway. This keeps the bottom bracket and pedal from being stressed.
I've had that same thought about a hitch receiver boattail..
The only issue with that is that it limits hatch access.
A roof container would be simpler, lighter and useful as storage for other things.
