Old 01-17-2020, 02:00 PM   #76 (permalink)
ldjessee00
The Leaf - '17 Nissan Leaf SL
Outback - '16 Subaru Outback
Vaquero - '20 Kawasaki Vulcan 1700 Vaquero ABS
I thought the same thing about RVs in the past, though I was thinking of a bigger battery, minimum Nissan Leaf sized (30kWh+).
I tend to look at the toy hauler versions (has a garage in the back; motorcycle), so I think about how to carry the motorcycle does not need that much vertical space, but would like it once stopped and setup... so instead of slide outs (which I think is a bad idea longevity-wise), how about the back pops up from a sport/camm back end?
When moving on the road, the back is at an angle, providing better aero, but when stopped, the back is 'popped' up and the toy storage has plenty of vertical area to stand up around the motorcycle, etc.
I could also see a living room/bed room being able to be done this way as well, as redpoint5 mentions. (do not need the vertical space when traveling)
The Following User Says Thank You to ldjessee00 For This Useful Post:
redpoint5 (01-17-2020)
