From the last time I ran the numbers, down 1 or 2 inches from stock, the factory headliner drops down a few inches and would get replaced with a tighter fitting setup. The taper where the seat is should only be down 3 or 4 inches at that point where your head is. So a net loss of an inch or two. Currently I plan to replace the seats on the third row with newer/different seats which may sit lower. If it ends up being more than that, i would lean the seat back back.
