Old 01-19-2020, 10:19 PM   #3 (permalink)
Tahoe_Hybrid
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
Originally Posted by M_a_t_t View Post
Are you mostly planning on doing drivetrain efficiency mods? You don't mention any plans for aerodynamics is why I ask.
Yes some Aero mods
under body (tire deflectors)and rear end
as you can see on #3 looks like there is a Aero issue
wing
the front end could use a few tweaks as well possibly installing a second air dam(found one for 39$ it's made for a vehicle ) I plan to add wheelbase side skirts as well
not sure if i will do a full Underbody (worried about the fuel vaporizing in the fuel line in the summer time as it gets very hot here into the 100 to 115F )
also LED lighting as well I modified some Sylvania Zevo LED 3157 bulbs and increased the brightness of them (it had some stupid plastic defuser on them deleted ) now they are SUPER crazy bright 2x2watt chips
it's like looking into the sun
I have to do something about the air wake in the rear it's a real drag (i see water pulled up from the ground when it's wet outside i.e not raining ) i don't see that on other SUVs
Looks like GM attempted to make it aero but that belongs on reddit /There was an Attempt
ID:	27458   Click image for larger version
ID:	27459   Click image for larger version
ID:	27460   Click image for larger version
ID:	27461   Click image for larger version
The Following User Says Thank You to Tahoe_Hybrid For This Useful Post:
aerohead (01-22-2020)
