Old 01-20-2020, 01:53 PM   #129 (permalink)
redpoint5
90 day: 29.78 mpg (US)
If you completely shut down the car before hitting 130 F and powered up again, would it re-fire? Or would it think the coolant is just cooling down from the last time the engine was used, and leave it alone?
I tried stopping/rebooting twice on today's trip, and it didn't make any difference -- engine re-fired each time, and it was definitely at full operating temp before the 2nd reboot.
If I turned off the HVAC or set it to the lowest setting, then it would not fire up the engine upon restart.
Any chance it was a scheduled engine run? I know the Volt will run the engine every so often if it hadn't run recently.
