Old 01-20-2020, 02:29 PM   #1 (permalink)
Eco4Driver
1992 Honda Civic VX D15Z1 Engine
Price $300
Contact:
Sergio B
Undiaf1 at yahoo dot com
I have a used Honda D15Z1 Vtec-E motor for sale. I purchased this with the idea of rebuilding it as I thought a high mpg Civic project would be pretty cool. I've changed my mind on that project since my pickup truck needs some attention.
This was pulled from a 1992 Honda Civic VX with some radiator support and undercarriage damage. I'm thinking the car maybe went into a ditch or hit a curb. There was a piece cracked off from the transmission bellhousing.
I ran the carfax and I believe this engine has either 183,000 or 283,000 miles. There is a mileage discrepancy in the vehicle carfax report, so that is why the ballpark mileage is hard to determine.
I have no idea if this engine is good enough to use as is. My intent was to rebuild it and I would recommend the same to an interested buyer.
The crankshaft spins and there is no excessive in and out play on the crankshaft. There is no heavy sludge visible.
The following parts are included in the sale.
1.) 1992 Civic VX engine harness
2.) 1992 Civic VX Dash harness
3.) 1992 Civic VX Main Harness
4.) 1992 Civic VX Left Side Engine bay harness
5.) Pigtails for connectors that are currently missing from the harnesses
6.) 1992 Civic VX EGR Control Valve
7.) Used NGK Civic VX 5 Wire O2 sensor
8.) Civic VX flywheel, clutch pressure plate, clutch disc
ID:	27468   Click image for larger version
ID:	27469   Click image for larger version
ID:	27470   Click image for larger version
ID:	27471   Click image for larger version
