Old 01-20-2020, 08:04 PM   #403 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
I wonder how much the stainless steel body will increase insurance rates for the CyberTruck. Scratches are one thing but with an unpainted surface you can’t use filler. That means body shops can’t hammer out or pull dents. To repair the main unibody the body shop needs to: cut out the dent, weld a repair panel in place, grind the weld smooth, and then seamlessly polished and blend the finish so the repair is invisible. They will have to match the oxidation on the old panels exactly. The repair has to be perfect.
The Following User Says Thank You to JSH For This Useful Post:
redpoint5 (01-20-2020)
