Old 01-24-2020, 10:30 PM   #3 (permalink)
racprops
Originally Posted by Tahoe_Hybrid View Post
3.08 final ratio is the modern one it will put you at 1800-1850rpm @ 85mph 0.73 4th gear
2.41 is the lowest you can go but you risk stalling the engine
you can lower the ratio further by putting taller tires...
For the Ford that would work, got any or know where I can get a 2.41 set??
The Chevy Van is getting low RPM torque monster 383 with its torque peek at 2000 RPMs...running a 85/90 Camaro TPI with matching PCU with Highway mode able to lean to 16.4 on light throttle and load.
It too could be golden at that ratio, same question where to get a set?
Thanks.
Rich
PS I have a 2.73 already.
