Old 01-25-2020, 01:08 PM   #7 (permalink)
racprops
I'm skeptical. In my experience, there's always a lower gear, unless you're already in first. If you can still accelerate in top gear, there's still room for improvement. A large change in rear end is basically like trading your bottom gear for an extra one at the top.
IF I could post a picture here with out a damn URL I could show you the charts of the transmissions RPMs in each gear from 500 to 5000 with the gear sets I want.
IN each case the first gears of the 6 & 8 speeds are running higher RPMs at 10MPH that the stock transmissions with the stock rear end gears. So the lower first gears are making MORE Power even with a 2.26 or a 2.47 than with the stock 3.27 gears.
So the numbers show a slightly higher performance off the line than with the stock transmissions with stock rear ends.
And at this time I am very happy with each vehicle's power off line and driving. This will just improve it.
I end up with more gears up to cruse and a very high final gearing.
From 1600RPMs to 2000 RPMs with both vehicle's.
Rich
