Originally Posted by Ecky
Corvette 7th gen. There are 8 generations, typically referred to as C1-C8. The C7 has incredible gearing. I believe the rear end for the auto is a 2.56 with a 0.67 6th gear, while the manual has a 3.42 rear end with a 0.42 7th gear. Tires are P285/35R19.
EDIT: I believe I recall seeing the C7 as being able to break 40mpg from the factory (at the right speed) with a 6.2L pushrod V8.
OK that is a 378 CI motor, very close to my 383 build.
I saw that about the C7 Corvette and it was more validation of my nearly 20 year old ideas.
Now to find a gear set in the ranges I am looking for.
Rich
