Originally Posted by Ecky
Corvette 7th gen. There are 8 generations, typically referred to as C1-C8. The C7 has incredible gearing. I believe the rear end for the auto is a 2.56 with a 0.67 6th gear, while the manual has a 3.42 rear end with a 0.42 7th gear. Tires are P285/35R19.
EDIT: I believe I recall seeing the C7 as being able to break 40mpg from the factory (at the right speed) with a 6.2L pushrod V8.
Yup.
Corvette 7th gen 14-17?
Triple over drive.
Version 1 7th: 0.50
Version 2 7th: 0.42
Interestingly they have pretty much used the same chassis and drivetrain since 1997. vvt and some changes, but besides the 0.42 ratio change a lot of it is extremely similar. In my mind the C7 is the C5 version 3.
