Old 01-29-2020, 01:15 PM   #49 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
There are 2 different potential energies involved. The height is the main but there is energy in the velocity of water as well. I remember the first time I encountered a ram pump lifting water without any power input. I thought it was some kind of perpetual motion machine or an optical illusion. You can have a stream on you property with only a few feet of elevation change but then lift a smaller portion of that water to a pretty good height above the stream without any input of outside energy.
The Following User Says Thank You to Hersbird For This Useful Post:
aerohead (01-29-2020)
