Old 01-31-2020, 12:07 PM   #15 (permalink)
redpoint5
90 day: 29.78 mpg (US)
I like those ideas. I've never used a DCFC, so everything is speculation to me.
Cable lengths are kept as short as reasonable (and sometimes shorter). It gets more expensive having extra length, and more length probably means it needs thicker gauge wire, which adds weight and reduces flexibility. Maybe the weight is why they aren't on a reel. Something does need to be done about cable management though.
Vehicles probably should standardize the location of the charging ports. You've got them just about everywhere at the moment. Once that's done, you can standardize the layout of charging stations. The island layout makes sense to me, so that would lend itself to drivers side charging ports, either just ahead of the front door, or just behind the rear door where a fuel tank would be.
aerohead (03-07-2020)
