Old 02-01-2020, 10:03 AM   #423 (permalink)
teoman
teoman's Avatar
A3 - '12 Audi A3
I see where you are going, do you have soemthing like an imax charger? Or means of measuring the capacity of each cell. After that you plug the capacities in to a website (jhurgia on youtube recommended it) and it tells you which pack goes in which parallel cluster.
I have a BMS that has a bluetooth interface so you can connect your phone to. Have not been able to test it yet. I also recommend a bms if lots of cells of unknown capacity are involved, especially if you intend on running them from max to min.
Also if you get that box, check its voltages. Some of them over or under read.
8 cells, if each of the required 2 amps and you wanted to usb charge them, you would need a 16A usb port.
In which case I doubt that the charging circuit is up to it. If it charges at 2A the it will take more that 8 hours to charge.
