Thinking on this a bit more. . .
Having a standard spark plug threaded into a heavy external chamber would work.
Injectors from a Direct Injection system that run at several hundred to thousands of PSI can feed the chamber with a side injection and would provide cooling.
Couple this with port injection of a lean mixture and your DIY system might be a possibility.
