Originally Posted by CapriRacer
If the patched tire is leaking, that's not a good indication.
I take that back, the patched tire is holding the same exact pressure as the other 3, at 47 PSI, so I left it alone. Unfortunately, I don't have a jack. Do OHTSU tires have a tendency to bulge? I believe they are made by Falken. If it's holding pressure normally, can I rely on it at 50 PSI, or at least 35 psi or should patched tires always be replaced? Not sure how to check monthly without a jack. Thanks in advance.
