Old 02-04-2020, 09:54 AM   #479 (permalink)
Piotrsko
I make my reservoirs from schedule 80 plastic pipe with appropriate glue in fittings.
If the vacuum is leaking from your master cylinder, you may need a rebuilt/ new booster. I have had a couple go bad. You want to get two brake applications engine off.
The Following 2 Users Say Thank You to Piotrsko For This Useful Post:
Ecky (02-04-2020), Pressingonward (02-15-2020)
