These orbit graphic representations are very wrong in scale, since if you would put real proportion of orbital distances, Pluto would not fit in your monitor.
I once saw a size analogy of planets in relation to the sun, using a school soccer field, placing the filed center as the SUn's location. While the first two planets or so was inide the circular center of the soccer field, you would need to take a car and run several blocks until get into the right distance of pluto to the center of the field.
